Rotation of imported graphics
If I import a graphic which has an unwanted orientation it would be very nice to have a function which allowes to do so.
Ok, if you have only on graphic this is not a big deal, but several …
Especially with a format like .webp which is not so commonly used in graphic applications. What I think is that this .webp format allows an attribute for orientation like graphics which are included in pdf as far as I know.
I use ‘Geeqie’. It allows to rotate but not to save the rotation to the file. If I open the file in Geeqie again the orientation is fine, it seems to me that it saves the orientation internaly. In Obsidian the orientation remains originaly so I have to open it in Gimp - which needs more time to load an rotate in Geeqie.
Anyway it would be nice to have a rotation function of graphics inside Obsidian.
A right klick on the wrong orientated graphic should open a context menu which has the function to rotate the graphic - a short cut on the selected graphic would be great as well.
I open the wrong orientated graphic with a graphic tool like Gimp to rotate the graphic in the orientation I want.
i also felt the need to have this but this is more likely to be implemented as a third-party plugin, not core functionality…
Hi Yurcee, you are right but sometimes miracles happen. :slight_smile:
It would be a little ‘mac like’ :wink:
tip: look around in excalidraw plugin’s scripts library…,maybe there’s something there…
Hi, thank you for your tip!
