I have an Obsidian Vault with many plug ins installed but I have turned on Restricted mode to turn them all off. I am also using the default theme.
When I open up a note and right mouse click over the tab at the top of the note, I expect to see a context sensitive menu to pop up with options click “Close tab” or “Close all tabs except this one”, etc, but no menu appears. It does appear in the Sandbox vault.
Also, when I left-click the “three dots”/Ellipsis (…) button on the top right of a note, I expect a drop down menu to appear but it does not. It does appear in the Sandbox vault.
My preference has always been to use the Legacy editor and the above functions have always worked using it but that is no longer the case. If I turn off legacy Editor mode, the functionality works as expected.
Could you make this functionality work once again with legacy editor Mode on?
Obsidian version: v1.3.7
Installer version: v1.3.4
Live preview: on <----Note that it works with it on, does not work if off
Legacy editor: off
Snippets enabled: 2
