Ribbon Bug and Fix
### Steps to reproduce
1. Create an empty vault with one community plugin that adds its ribbon icon after an async step in `onload`. Many plugins do this (`await this.loadData()` → `addRibbonIcon`), e.g. Kanban and Templater. Minimal plugin:
```js
const { Plugin } = require(‘obsidian’);
module.exports = class LateRibbon extends Plugin {
async onload() {
await new Promise((r) => setTimeout(r, 500)); // stands in for `await this.loadData()`
this.addRibbonIcon(‘dice’, ‘Late ribbon icon’, () => {});
2. Hide that icon (right-click ribbon → uncheck), or set `.obsidian/workspace.json` → `“left-ribbon”: {“hiddenItems”: {“late-ribbon:Late ribbon icon”: true}}`.
3. Open the vault on a device that has **never opened it before**: a new machine, a reinstall, a fresh app-data folder, or a vault that arrived via Sync or git.
Full repro files: Obsidian 1.14.4: plugin ribbon icons' hidden state is reset and erased on a vault's first open on a device (repro + fix + workaround) · GitHub
### Did you follow the troubleshooting guide? [Y/N]
Y. Default theme, no snippets. Restricted mode can’t be used because the bug needs a community plugin, so the repro uses the single minimal plugin above.
### Expected result
The icon stays hidden, as saved in `workspace.json`.
### Actual result
- The icon is shown.
- The layout is saved before the plugin registers its icon, so its entry is **removed from `hiddenItems`**. The choice is lost permanently, not just for one session.
- 3/3 on first open; 0/3 on later opens of the same vault on the same device.
### Environment
Obsidian version: 1.14.4
Installer version: 1.8.9
Operating system: Darwin Kernel Version 27.0.0: Tue Aug 11 21:02:57 PDT 2026; root:xnu-13432.1.9\~1/RELEASE_ARM64_T8132 27.0.0
Plugins installed: 2
Plugins enabled: 1
    1: Late Ribbon (repro) v0.0.1
### Additional information
**Cause (from app.js, same code in 1.8.9 and 1.14.4):**
- `WorkspaceRibbon.load()` applies saved `hiddenItems` only to items already in `this.items`.
- `addRibbonItemButton()` creates unknown items with `hidden: false` and never checks the saved state.
- `serialize()` writes only the items that currently exist, so entries for icons that haven’t registered yet are dropped.
**Suggested fix:** keep the loaded map (`this.savedHidden = hiddenItems`). Use `hidden: this.savedHidden[id] ?? false` for new items in `addRibbonItemButton`. Merge in `serialize()` (`{…this.savedHidden, …current}`) so icons from plugins that haven’t loaded yet, or are disabled, keep their entry.
**Related:** the language-switch reports 84190, 71643 and 117524 have the same root cause. Ribbon IDs are `pluginId + “:” + localized title`, so after a language switch no saved key matches, and `serialize()` then erases the old keys. Fixing that case also needs a stable, non-localized ID.
**Workaround:** a small plugin that re-applies the saved value when an icon first registers (in the gist).
