Reversing the Order of System Prompts in Templater Plugin
Hello,
I’ve been using the Templater plugin to create notes in Obsidian. Currently, when I use this sequence in my template:
<% tp.system.prompt("Question 1") %>
<% tp.system.prompt("Question 2") %>
<% tp.system.prompt("Question 3") %>
the prompts ask for input starting from Question 3 to Question 1, instead of 1 to 3. Is there a way to reverse this so they are prompted in the order they appear in the script?
Does anyone know if this functionality exists within Templater?
I want the input prompts to appear in the order they are listed in the template.
I’ve looked through the Templater documentation but haven’t found anything related to reordering the prompts.
Any advice or solutions would be much appreciated!
Okay I found a solution. It works like this:
let question1 = await tp.system.prompt("Question 1");
let question2 = await tp.system.prompt("Question 2");
<% question1 %>
<% question2 %>
Or alternatively this also works:
<%await tp.system.prompt("Question 1");%>
<%await tp.system.prompt("Question 2");%>
