Restore does nothing if parent directories do not exist
  1. Create Note in subfolder
  2. Delete subfolder
  3. Go to “File recovery: Open local history”
  4. Find the note that was delete
  5. Click restore.
  6. Nothing happens.
Tested in sandbox. Debug info is from my usual vault.
I expected the parent directories to be created or a feedback that something has gone wrong.
Nothing.
Obsidian version: v1.10.6
Installer version: v1.7.6
Base theme: light
Snippets enabled: 1
Plugins installed: 3
Plugins enabled: 3
1: Advanced Tables v0.22.1
2: Pixel Perfect Image v1.0.17
3: Text Format v3.1.0
I can reproduce this problem. MacOS Sandbox, Obsidian 1.10.6 installer 1.9.14. Console error below.
It seems to depend where the note was created.
I just tested in the Sandbox vault and it works if the note was created outside of the folder.
  • Create a folder.
  • Create a note in the root folder.
  • Move the note inside the folder.
  • Make a few edits. Wait for there to be file history.
  • Delete the entire folder.
When I click “Restore”, it puts it in the root of the Sandbox vault.
It fails if the note was originally created in the deleted folder.
  • Create a folder.
  • Right-click to create a note inside that folder.
When I click “Restore”, the operation is unresponsive. No feedback in the GUI. The file is not recreated. The “Copy” button still works.
And an error occurs in the console:
I just did two another tests:
  • Make a test folder
  • Right-click and add a note inside that folder
  • Make edits and wait until there is file history
  • Move the note into the root folder
  • Delete the subfolder
  • Then delete the note
  • Then try to restore the note. It still fails.
Another test:
  • WAIT to make sure there is time for file history. Waiting doesn’t do anything. Until an edit is made on the file, File Recovery still thinks it is inside the folder. If the folder is deleted now, it will fail. If you right-click to show file history, it will show the note as having the deleted subfolder path.
  • Make some edits to the file and wait. Now File Recovery knows it is in the root folder. Now Restore will work.
will be fixed 1.11.2. No ETAs.
