Before opening a new bug report, please search the forum for duplicates and follow the Troubleshooting Guide.
- We only consider bugs that are reproducible in the sandbox vault or a vault with no third-party plugins/no css snippets/default theme.
- For Linux, we only accept bug reports that are reproducible with our Appimage or Snap package under Gnome or KDE.
- Developer issues with the API should go here
- Themes and Custom CSS issues should go here
- Translations issues/improvements should be posted here
- Obsidian Clipper Bugs should be posted here
- Obsidian Importer Bugs should be posted here
From a new vault, create a base and a canvas. Insert the base into the canvas. You may need to add a second property to the base so there are more than one column. When you try to resize a column in the base inside of canvas, after unclicking to get the column to the desired size, a new canvas card gets added.
Y
I expect the column to resize only, with no new card created.
The column resizes, and a new blank canvas card is created.
Obsidian version: v1.9.4
Installer version: v1.8.4
Operating system: Darwin Kernel Version 24.5.0: Tue Apr 22 19:54:26 PDT 2025; root:xnu-11417.121.6~2/RELEASE_ARM64_T8112 24.5.0
Catalyst license: supporter
Insider build toggle: on
