I have a custom template that I use to place text with in a <pre>
block, especially code snippets. I prefer more control w/ a custom <pre>
template as opposed to ``` i.e., I can highlight, italicize, emphasize, etc.
The issue is what I copy templated C++ code, or any code for that matter, that uses <
and >
the editor view doesn’t render unless I go full on out to Preview Mode. I would like to have a template (or whatever) solution to selecting the code that I am about to place under a block and replace each instance of <
with <
. Right now I am resorting to a Python script that does this separately.
I believe my question is similar to Templater: replacing " " with "_", but I keep failing in trying to leverage it.
