I am trying to make my custom CSS for @media print. And after I set the rendering in developer tools. There is nothing rendering in Obisidan, I can see that everything is there in the code. But nothing shows.
Hello!
If your custom CSS for @media print isn’t rendering in Obsidian, check your syntax, clear the cache, use developer tools to inspect the CSS, update Obsidian, and ensure theme compatibility. If the issue persists, consult Obsidian community forums or GitHub for solutions.
It does not work when I turn off custom css. When I activate “rendering: print” in developer tools it shows nothing.
If you share the css you are tying to use, in a code block, folks can have a look and maybe offer suggestions.
