- I have a few Obsidian notes Opened in different Desktops(MacOS):
- a canvas note
- an excalidraw note
- the main window and other markdown notes window
- Typing in the main window on a regular markdown note.
- The main window turned black and there is a “Obsidian Helper (Renderer)” reported in console.app
Didn’t try in sandbox vault, but under any circumstances, the render process should never crash itself.
Obsidian runs normal
Main window turned black
Obsidian version: v1.7.7
Installer version: v1.7.4
Operating system: Darwin Kernel Version 24.2.0: Fri Dec 6 19:01:59 PST 2024; root:xnu-11215.61.5~2/RELEASE_ARM64_T6000 24.2.0
Catalyst license: none
Community theme: Serenity v2.0.9
Snippets enabled: 1
Plugins installed: 74
Plugins enabled: 59
1: Quick snippets and navigation v1.0.10
2: Paste URL into selection v1.7.0
3: Quick Explorer v0.2.12
4: Rollover Daily Todos v1.1.8
5: Shortcut Launcher v1.1.0
6: Table Extended v1.6.1
7: Outliner v4.8.1
8: Paste image rename v1.6.1
9: Periodic Notes v0.0.17
10: QuickAdd v1.11.5
11: Slash Commander v0.2.16
12: Solve v1.0.3
13: Tasks v7.14.0
14: Templater v2.9.1
15: PDF++ v0.40.21
16: PlantUML v1.8.0
17: Recent Files v1.7.4
18: Omnisearch v1.25.2
19: AsciiDoc Blocks Plugin v1.0.2
20: Book Search v0.7.5
21: Change Case v2.0.139
22: Checklist v2.2.13
23: Clear Unused Images v1.1.1
24: Completr v3.2.0
25: CSV Codeblock v1.1.0
26: Dataview v0.5.67
27: DB Folder v3.5.1
28: Divide & Conquer v1.0.0
29: File Color v1.1.0
30: floating toc v2.4.7
31: Footnote Shortcut v0.1.3
32: Full Calendar v0.10.7
33: Gemini Assistant v1.0.4
34: Git v2.31.1
35: Global Proxy v1.0.4
36: Hider v1.5.1
37: Hotkeys for templates v1.4.3
38: Hover Editor v0.11.21
39: Iconic v1.0.15
40: Importer v1.6.19
41: Kindle Highlights v1.9.2
42: Latex Suite v1.9.7
43: Linter v1.28.0
44: List Callouts v1.2.9
45: Local GPT v1.14.7
46: Local Images Plus v0.16.0
47: Mind Map v1.1.0
48: Ninja Cursor v0.0.13
49: Nomnoml Diagram v1.2.0
50: Note Gallery v0.0.60
51: Number Headings v1.16.0
52: Numerals v1.5.0
53: 盘古 PanGu v1.6.2
54: Vertical Tabs View v2.6.0
55: Time Ruler v2.5.2
56: Text Format v3.1.0
57: Day Planner (OG) v0.6.2
58: Excalidraw v2.7.5
59: Auto Link Title v1.5.5
OS: macOS Sequoia 15.2
The backtrace
The main window:
The other canva window:
