Renaming note by clicking Tab, as previously renaming a note by clicking title?
Clicking the tab, searching online, searching settings.
I’d like to be able to rename a note by clicking the tab, as it was previously easier to click the note title to rename a file name than having to right click and navigate the context menu.
There is this thread here, Unable to rename a tab by clicking the vertical title, though it seems to have been deleted. Don’t know if they figured it out themselves?
Am I missing something?
Thanks!
Not sure if that’s possible, right now.
An alternative would be to switch on the setting Appearance → Advanced → Show Tab title bar. It’s rather non-obtrusive.
Or if it’s clicking and foraging through the context menus that is inconvenient, you can just use the rename file hotkey (F2 by default), assuming you are on PC.
The title bar things is perfect, thanks!
FYI you can also rename via the note menu (the 3 dots at upper right) or command palette.
Thanks!
