RemotleySave-Sync Error: SocketException Connection reset
Background
  1. I can sync on windows Obsidian via RemotelySave, I have two PCs, the plugin works well on both PCs.
  2. I have a Android phone, can’t sync and show below error:
If somebody had this issue before, please advise your solution, thank you.
  1. On Remotely Save Github, I have found one issue post, but no solution.
  2. I have deleted the whole folder on my Android, and copied the whole folder from my PC to it, but it can’t work.
anyway, I changed to sync with Dropbox, it’s faster, 2GB storage is enough for me now.
