Remembered window size changes depending on scaling settings of the monitor Obsidian starts on
  1. Open Obsidian.
  2. Resize the window to the desired size and position on a second monitor.
  3. Close Obsidian.
  4. Reopen Obsidian.
  5. The application’s window will open on the second monitor and be a different size.
Y
The window size should remain as it was at the end of the previous session upon starting a new session.
The window size changes (shrinks dramatically, in my case) in relation to the previous session’s window size upon starting a new session.
Obsidian version: v1.4.5
Installer version: v1.3.5
Operating system: Windows 10 Home 10.0.22621
Legacy editor: off
Community theme: Obsidian gruvbox v0.1.7
Plugins installed: 1
Plugins enabled: 1
1: Creases v0.7.0
If I position Obsidian onto my main monitor, it retains its size between sessions correctly. My main monitor (2560 x 1600) is scaled to 150% in Windows 11’s System > Display > Scale & Layout > Scale, while my secondary monitor (1920 x 1080) is scaled to 100%. The secondary monitor is the one that’s having trouble retaining proper Obsidian application window size between sessions.
Screenshots on main monitor (non-problematic monitor)
Main monitor, before closing application:
Main monitor, after closing and reopening application:
Screenshots on secondary monitor
Secondary monitor, before closing application:
Secondary monitor, after closing and reopening application:
Secondary monitor, after closing and reopening application again:
Monitor configurations
Monitor 1’s settings (the non-problematic monitor):
Monitor 2’s settings (the monitor that exhibits the bug) :
Came to report the same thing.
