Hi All
I am trying to figure out why Readwise imports adds the title twice , it’s a bit frustrating is there any way to remove this ?
Hi All
Have you checked your Readwise template? These kinds of issues are usually solved over there.
I am a bit of a novice not even sure what I should be looking for
I have switched off Inline Title which seems to have fixed the issue.
