^ image 1 (correct formatting) & image 2 (incorrect formatting)
TLDR: if there exists a list, and there exists a task within that list, if there is any space between any two items in that list, tasks will not render properly
- Create a new note in Obsidian.
* Enter the following Markdown code for a continuous task list:
# list
- [ ] task 1
- [ ] task 2
- [ ] task 2.1
- [ ] task 3
- item 1
- [ ] task 4
* Observe that the formatting renders correctly (as shown in the first image).
* Now, modify the task list by adding a blank line between the last two items (or any two items):
# list
- [ ] task 1
- [ ] task 2
- [ ] task 2.1
- [ ] task 3
- item 1
- [ ] task 4
* Observe that the formatting breaks (as shown in the second image).
* try adding a blank line between any items in a list, you will get similar issues
Yes, I tested the issue in a sandbox vault with no plugins or custom CSS.
The task list should maintain consistent indentation and formatting regardless of the presence of blank lines between items.
When a blank line is introduced between items in a task list, the indentation and formatting of subsequent items are disrupted, leading to inconsistent rendering.
Obsidian version: 1.8.4
Operating System: [Your OS here, e.g., Windows 10, macOS Monterey, etc.]
- The issue occurs regardless of where the blank line is placed, as long as there is a task list item present.
- i.e. if there exists a list, and there exists a task within that list, if there is any space between any two items in that list, those tasks will not render properly
