Reading View: Less space between block quote and heading than between paragraph or list and heading
  1. Make a note with the following content:
    (XXXXXXX) XXX XXXX XXXX XX XXXXX XXX XXXX, XXXX XXX X XXXXXX XXXX XXXX XX XXXXXX.
    ## XXXXXXXXX
    > XXX XXXXX XXXXXX XXXXX XXX XXXXX?  ([‎‘XXXXX XX XXXXXXX’](XXXXX://XXXXXXXXXX.XXX/XXXXX-XX-XXXXXXX/))
    ## XXXXXXXXX
    - XXX XXXXX XXXXXX XXXXX XXX XXXXX
    ## XXX
    :: 2025-X28-1 02:12 (7/7) :: XXXXX, XX 30X13X.
  2. Switch to Reading View.
Y
There should be the same amount of vertical space between any text block and a subsequent heading. (Preferably more than a single line.)
Apparently this affects callouts too but I haven’t tested it myself. Discord
There is less space between a block quote and a subsequent heading (1 line) than between a paragraph or list and a subsequent heading.
Operating system: ios 26.0 (Apple iPad13,1)
Obsidian version: 1.9.12 (237)
API version: v1.9.12
Catalyst license: none
This CSS snippet patches it.
/* Add space between block quote / callout and subsequent heading to match the larger space that follows a paragraph or list. Bug report: https://forum.obsidian.md/t/reading-view-less-space-between-block-quote-and-heading-than-between-paragraph-or-list-and-heading/105212
Snippet by @_floodlight https://discord.com/channels/686053708261228577/702656734631821413/1413011100089319444
.markdown-rendered :is(.el-div, .el-blockquote) + div > :is(h1,h2,h3,h4,h5,h6) {
  margin-block-start: var(--heading-spacing);
same here (on windows) inside the sandbox vault, without any community plugins
Obsidian version: v1.9.14
Installer version: v1.8.3
thanks
Should be fixed in 1.12
It is!
