Reading Inbox Synthesizer — turn your web clipping backlog into reading memory
Disclaimer
Is this project completely free? No (free tier + one-time Pro license at $19.99)
Community Directory: [Reading Inbox Synthesizer](https://community.obsidian.md/plugins/reading-inbox-synthesizer)
I clip a lot of articles into Obsidian with the Web Clipper. The problem is that I almost never go back to read them. A month later I would have 40-something clippings sitting in a folder and no memory of which ones were actually worth my time.
I looked for something that could read the whole pile for me and tell me what was in there without opening every note one by one. I couldn’t find anything that worked across the accumulated backlog rather than one article at a time, so I built it.
How it works
You point it at your Clippings folder or tag. It calls your own LLM provider and reads each clipping. Nothing leaves your vault except the call to your provider.
What it produces:
  • A short summary and the key claims for each article
  • Cross-article themes that show where your sources agree and where they contradict each other
  • A weekly section for what you saved recently
  • A “needs attention” list that flags clippings sitting untouched for months
Supported providers: Anthropic, OpenAI, or any OpenAI-compatible endpoint including OpenRouter.
I’m curious how other people handle their own clipping backlog in Obsidian. Do you process clippings as you save them, batch them later, or just let the folder grow? I’d like to hear what actually works for you.
Source: [GitHub](https://github.com/ibrh96-prog/obsidian-reading-inbox-synthesizer)
Pro license (optional): [Gumroad](https://ibrh96.gumroad.com/l/yeulsi)
Quick context note (not a new release).
With Pocket gone and a lot of people migrating their reading into Obsidian via the Web Clipper, I’ve been seeing the same thing come up: the saving problem is solved, but the backlog problem isn’t. The pile just moves into the vault.
That’s the spot this plugin works in — it synthesizes the clipped backlog into one note (per-article summaries, cross-article themes, what’s gone stale) so the pile stays triageable instead of becoming a graveyard.
Sharing in case it helps anyone who arrived here post-Pocket. Curious how others are managing their reading backlog in Obsidian now.
RIP Pocket. Going to try this out. Question, though: are Inoreader, Cubox, Omnivore, and/or Anybox all non-starts for a lot of people?
Valid question. Those are great standalone tools, but for many Obsidian users, they introduce friction and siloed data.
There are a few objective reasons why people prefer to dump things directly into Obsidian rather than using Inoreader, Cubox, or Anybox:
Data Ownership: Obsidian is local-first. Putting reading material into another cloud service runs the risk of that service shutting down or changing business models (like Pocket, or more recently, Omnivore).
Frictionless Linking: When the clipping is already in the vault as a markdown file, integrating it with existing notes via standard backlinks is immediate. Syncing from third-party apps often requires brittle integrations that break.
Consolidation: Bouncing between a dedicated read-it-later app and a note-taking app breaks focus. Users generally want a single source of truth.
The official Web Clipper made getting data into Obsidian seamless. The bottleneck just shifted from “saving the article” to “processing the pile,” which is the exact mechanical gap this synthesizer attempts to fix.
Quick update — v1.1.0 is live.
Added a “Get Pro license” prompt that shows up when you hit the free-tier limit (3 syncs), plus a persistent upgrade section in Settings under License. Previously there was just a dismissible notice with no link — easy to miss that Pro existed at all.
No changes to the sync/report logic itself, just makes the upgrade path visible. Free tier is still 3 syncs total, generating the report from already-synced content stays unlimited either way.
Excellent explanation, thank you!
Small update: v1.1.1 is out. Raised the free tier from 3 to 10 lifetime syncs (still a one-time lifetime allowance, not a subscription or a monthly reset) and rewrote the upgrade prompt to say what’s actually waiting to be synced instead of a generic “upgrade now” message.
Community Directory: Reading Inbox Synthesizer
