I have created a script to activate a “reader view” on an Obsidian Publish site, it works with sliding windows or without (but I have not tested it with sidebar disabled by default).
This view can be useful to visualize poetic texts or to browse through images as a portfolio or simply to have a clearer view while reading. Now you can activate the “reading view” in 4 different ways:
- using a button
- pressing the “r” key
- by defining the reader-view class in the cssClass property in the frontmatter
- adding
?reader=true to the url of the page.
I have implemented the script on my Publish website.
Here an example activating the script via url, where you can find the code (also on Github)
This is brilliant, and it needs more attention.
I wonder if it’s worth it/possible to also reduce the alpha on scrollbars in this view so they are less obtrusive.
This was exactly what I was wondering about. It would be great to have a scrollable one, but it doesn’t seem very easy. I also noticed the image modals in yours if you click on an image. This was another issue I ran into when sharing tutorials where the images are quite large.
Thanks a lot!
You mean when Reader view is activated? Yes, I had put myself but I did not finish closing, I will do it soon.
Great! Looking forward to seeing it.
By default Publish displays scrollbars only when scrolling. I have been able to customize the look of the scrollbars but by adding any css selector, the bars are always displayed, even when you do not scroll: at this point it becomes meaningless I guess. I would have to understand how the web works (maybe it’s a css transition?) but I don’t know if it’s worth it: with Safari and Chrome the scrollbar is almost imperceptible, it becomes temporarily intrusive when you click on it but it is a brief moment…
Is it the same behavior for you?
