Re-enabling sync after renaming vault folder
How should I re-enable sync in a way that will avoid problems? Do I need to create a new remote vault or can I just pick my previous remove vault and expect that it understands what to remove?
Why this happened
  • I moved some content out of a vault that was set up for sync because obsidian was slow.
  • I did this in windows explorer
  • After doing it, obsidian was hanging on opening at loading cache.
  • A solution mentioned in forums was to rename the vault folder Stuck on Loading cache - #38 by mw998
