Quick switcher to jump to headers
Possibility to jump to headers in a file using the quick switcher. Current behaviour only allows switching between files. Similar to backlinking to headers.
Should use the current default text to ![[link#heading]] to a note. Without [] of course. So you’d type a title and when it’s highlighted hit # and then get a list of headings that you can jump to.
Yes, with that you deal with both functions in more or less the same manner.
@alper There is a quick switcher+ plugin which allows jumping to the header using quick switcher.
