- You know the use of aliases.
- You can easily add aliases to one-word titles. America=US=United States=USA
- When you add a concept involving this one-word note, you could use any of the aliases
- For example,
The poor in the US=Poverty in America - The problem is when searching back for this note, you might actually enter
Poverty in the US. No matches!
I suggested before aliasing words (e.g. US) wherever they occur. But here I want to suggest that, using only the aliases mentioned in the example above, mix and match words in them while looking for a note.
Poverty in the US should match.
