Quick Element Insert
Easily insert a custom styled element rather than typing it out or copy and pasting the code for it every time.
For example being able to run something like /badge_test would insert something like:
<span class="badge test">Test</span>
Looking around the community.
Thanks in advance,
~Blood
is one option you could try.
This looks exactly what I’m looking for honestly. Might see if there’s something else though, seems like that hasn’t been touched for a good 3 years. :slight_smile:
Thanks for informing of this though. :smiley:
is another one, using its “Wrapper” feature. Updated 22 months ago, if that’s any better for ya.
I would make a templater template and bind it to a hotkey
Don’t go wild now! /j :grinning_face:
Another great option!
I use Easy typing.
I have set it up so I can select the text for the class name and then type ! to to get the span class.
It can be customised for your purpose too.
I’ll be having a look at these today hopefully and give a solution soon.
Thanks for the recommends. :smiley:
