So I’m trying to create a tag #Mood Disorders but it isn’t showing up as a single tag. I attempted #[[Mood Disorder]] but that creates a backlink instead. Is there a way to do this?
You can’t have tags with multiple words, the only workaround (I know of) is to use hyphens.
Like this #Mood-Disorder.
I don’t really use tags that much, so maybe someone knows of a better way to this.
There are alternatives, though I don’t believe they’re better. They all aim at us reading two words as a single word when Obsidian sees only one.
in addition to hyphens, periods should also work, with the plus that they’re terminal safe.
