I have recently set up security auditing on my local workstation. This auditing has picked up on a hidden file that is being created in the /tmp directory and is owned by root:root even though the Obsidian app is being run under a normal user account using the Appimage installer.
The directory in the /tmp directory is only present when Obsidian is running and has the name format of .mount_obsidi<random_string>
See example below:
> ls -la /tmp
drwxr-xr-x 5 root root 0 Dec 25 19:19 .mount_ObsidikcDNzJ
ls -la /tmp/.mount_ObsidikcDNzJ ✔ base
total 208372
-rwxr-xr-x 1 root root 2349 Dec 25 19:19 AppRun
-rw-r--r-- 1 root root 136579 Dec 25 19:19 chrome_100_percent.pak
-rw-r--r-- 1 root root 197691 Dec 25 19:19 chrome_200_percent.pak
-rwxr-xr-x 1 root root 1246464 Dec 25 19:19 chrome_crashpad_handler
-rwxr-xr-x 1 root root 53840 Dec 25 19:19 chrome-sandbox
lrwxrwxrwx 1 root root 49 Dec 25 19:19 .DirIcon -> usr/share/icons/hicolor/512x512/apps/obsidian.png
-rw-r--r-- 1 root root 10544880 Dec 25 19:19 icudtl.dat
-rwxr-xr-x 1 root root 251064 Dec 25 19:19 libEGL.so
-rwxr-xr-x 1 root root 2877488 Dec 25 19:19 libffmpeg.so
-rwxr-xr-x 1 root root 6437608 Dec 25 19:19 libGLESv2.so
-rwxr-xr-x 1 root root 4565640 Dec 25 19:19 libvk_swiftshader.so
-rwxr-xr-x 1 root root 6396248 Dec 25 19:19 libvulkan.so.1
-rw-r--r-- 1 root root 1096 Dec 25 19:19 LICENSE.electron.txt
-rw-r--r-- 1 root root 8247912 Dec 25 19:19 LICENSES.chromium.html
drwxr-xr-x 2 root root 0 Dec 25 19:19 locales
-rwxr-xr-x 1 root root 166365776 Dec 25 19:19 obsidian
-rw-rw-r-- 1 root root 225 Dec 25 19:19 obsidian.desktop
lrwxrwxrwx 1 root root 49 Dec 25 19:19 obsidian.png -> usr/share/icons/hicolor/512x512/apps/obsidian.png
drwxr-xr-x 3 root root 0 Dec 25 19:19 resources
-rw-r--r-- 1 root root 5214565 Dec 25 19:19 resources.pak
-rw-r--r-- 1 root root 259202 Dec 25 19:19 snapshot_blob.bin
drwxrwxr-x 4 root root 0 Dec 25 19:19 usr
-rw-r--r-- 1 root root 578034 Dec 25 19:19 v8_context_snapshot.bin
-rw-r--r-- 1 root root 107 Dec 25 19:19 vk_swiftshader_icd.json
It appears that these files are essentially the extracted contents of the appimage and possibly represent the files needed for Obsidian to run.
Is this the case? If so, why would the files be owned by the root user and root group?
I’ve tested this with a fresh vault with no plugins installed and the result is the same.
I’ve done a pretty extensive search and haven’t found any reference to this behavior, so just making sure that I’m not ignoring something that could potentially indicate a compromise or risk of compromise.
Thank you in advance.
