Querying complex data types from metadata using dataview
Hi all, I’m a new Obsidian user. I’m stuck with something that seems pretty basic, but unfortunately I was not able to find out the answer…
Consider this metadata YAML block:
cast:
  characterA: actor1
  characterB: actor2
What would be the right way of showing a table with 2 columns: “Character Name” and “Actor Name”?
My intuition was to try to somehow select FROM the cast field, but I was not able to do it.
All I am able to obtain is a table such as this:
cast(1)
  • characterA: actor1
  • characterB: actor2
Which I guess is not terrible, but not really what I wanted.
Any tips? Thanks in advance,
Rogério.
By the way, the query I used was simply this:
TABLE WITHOUT ID
cast
WHERE file.name = this.file.name
```dataview
TABLE WITHOUT ID cast.characterA, cast.characterB
Something like this?
Does this work?
```dataviewjs
// Assigns the page's cast entry to cast
const cast = dv.current().cast
const array = []
// Pushes each key and value pair to array
for (const [key, value] of Object.entries(cast)) {
	array.push([key, value])
// Render table with headers and array as data
dv.table(["Character Name", "Actor Name"], array)
I totally misread the request, and there isn’t currently a proper way to get the keys of an object using a DQL query. I just read your request related to how to get to the fields within the object, cast. Sorry for misunderstanding.
You’ll need to use a query like the one provided here by @AlexTheSleepy , or you need to retype your keys, and do something like:
```dataview
TABLE WITHOUT ID character as "Character name", cast[character] as "Actor name"
FLATTEN list(
  "characterA",
  "characterB" ) as character
WHERE file.path = this.file.path
Which also would produce:
Thanks a lot, both @holroy and @AlexTheSleepy!
Yes, Alex’s answer is indeed the one I was looking for… I was 99% sure dataviewjs was the way to go, but I did want to know if a “pure” DQL query would be possible.
My vanilla/frontend JavaScript knowledge is not that bad, but dataviewjs is still very unknown to me, will definitely dig deeper into it.
