Query to Return not based on order of values
Hi all,
I am trying to return notes based on some metadata. I have been using Obsidian for only about two weeks. I am using this code to return notes.
TABLE arpabet as "arpabet", arpatype as "arpatype"
FROM "words"
WHERE contains(arpatype, "FrU VoM")
sort file.ctime desc
Here is a visual if it helps:
I would like to return notes that contain the values in any order. So for this example
"FrU VoM" or "VoM FrU"
the more simple solution: WHERE contains(arpatype, "FrU VoM") OR contains(arpatype, "VoM FrU")
There’s the reverse() function… but in strings it works like a mirror
That makes sense. :+1:t2:
What would you do if the number of values increases? Instead of 2, we go with 3+. Would we have to just expand the logic on a case-by-case basis?
Well, the problem is: we are not talking about values (in the logic key: value) but in strings. More specifically, in substrings.
Unless you know a powerful regex (I don’t, neither the simplest one :slight_smile: ) I don’t know how to apply a filter to a substring and its reverse.
lol – yeah, I will keep looking. :slight_smile:
I’ll use your current solution for the time being though!
but you can use this logic
WHERE contains(arpatype, "FrU") AND contains(arpatype, "VoM")
a sum of substrings… order doesn’t matter (but it does not ensure that they are together)
That is what I was looking for!
Here is a visual for future readers.
Notice how the two words returned have all three values but in different orders. That is what I was attempting. Thanks @mnvwvnm!
