Deleting the large files, purging, restarting Obsidian, disconnecting the vault and reconnecting it to sync. I also tried excluding my attachments folder, unchecking sync images, etc. previously.
I am trying to sync my vault that had previously exceeded the limit. I removed large files and my folder size is less than 10gb but it is not syncing. The sync “Vault size over limit” feature still shows them under “View largest files” and Purge is not working.
Thank you so much for your help and quick response!
I have three devices. The sync log looks like this on two of them and the third was out of date so I tried to update it. Hovering was saying “Vault over size limit.” I also tried disconnecting all of them and re-syncing my most updated vault, but that didn’t work either and the log remained the same.
