Pulling note blocks into dataview
Hi There
I’m trying to collate a particular section of multiple files into a summary file.
== Example File 1 ===
## Conclusion
  • ABC
  • DEF
== Example File 2 ===
## Conclusion
  • [>] EZY
  • [<] BCD
=== Example summary file ===
## Conclusion summary
  • ABC
  • DEF
  • [>] EZY
  • [<] BCD
```dataview
LIST FROM “experiment”
WHERE meta(section).subpath = “Conclusion”
I know if they are task, then the above query would work, but since they are content section where they can be bullet points or short paragraphs, I’m not sure how to dynamically pull them into a single file.
Any insights or help would be great.
