Okay, so, for two month, I test Publish to help my classmate during our revision and examen.
As I use a lot Admonition, I use the publish.js to render my admonition. Unfortunately, It doesn’t support markdown…
Until I work a day on it.
(A day because I forgot to edit one word)
So, how can I do that ?
I first add :
function injectScript(src) {
return new Promise((resolve, reject) => {
const script = document.createElement('script');
script.src = src;
script.addEventListener('load', resolve);
script.addEventListener('error', e => reject(e.error));
document.body.appendChild(script);
injectScript('https://cdn.jsdelivr.net/npm/marked/marked.min.js')
.then(() => {
console.log("script loaded");
}).catch(error => {
console.log(error);
In the start of my publish.js file.
After, I looking for a lot and edit the admonitionContent.innerHTML = content; in processAdmonitionBlock.
The new line is admonitionContent.innerHTML = marked.parse(content);
And I do some… Try.
Also, note : it doesn’t work with Wikilinks (obviously).
You can see here the live rendering :
Live rendering
For the moment my problem is around the way Obsidian charge the JavaScript, but I think this trick can help on some Jekyll template, to force admonition view.
It is possible that you need to reload two times to get the parser to work.
