Provide RPM package for Linux distributions
Better system installation on RPM based Linux distribution e.g. Fedora
Provide an RPM package of Obsidian at Download - Obsidian
[This request is being made on the basis that a distribution specific package format, Deb, is already being provided]
I’ll second this one.
As an infrastructure admin, I’d like to be able to deploy Obsidian on RedHat/SuSE Enterprise for users who want it, where AppImage and flatpak are forbidden by policy, and DEB packages are time-consuming (expensive) to convert.
Would it be possible to update IT policies to add Flatpak as an installation method? RHEL and SLES include Flatpak as part of their base desktop package installs and officially support it as an application install method:
The LibreOffice RPM packages are now deprecated and will be removed in a future major RHEL release. LibreOffice continues to be fully supported through the entire life cycle of RHEL 7, 8, and 9.
As a replacement for the RPM packages, Red Hat recommends that you install LibreOffice from either of the following sources provided by The Document Foundation:
    The official Flatpak package in the Flathub repository: https://flathub.org/apps/org.libreoffice.LibreOffice.
    The official RPM packages: https://www.libreoffice.org/download/download-libreoffice/.
 In addition to the GNOME Package Updater, GNOME provides GNOME Software which has the following functionality:
    Install, update, and remove software delivered as an RPM via PackageKit
    Install, update, and remove software delivered as a Flatpak
    Install, update, and remove GNOME shell extensions (https://extensions.gnome.org)
    Update firmware for hardware devices using Linux Vendor Firmware Service (LVFS, https://fwupd.org)
Flatpak is designed for central application management similar to RPMs, so remotes can be self-hosted as RHEL and Fedora have done:
Fedora had also initially rolled out its Flathub support with a filter policy so only select applications could be installed by default:
https://fedoraproject.org/wiki/Changes/Filtered_Flathub_Applications
https://fedoraproject.org/wiki/Changes/UnfilteredFlathub
IT infrastructure could self-host and/or approve certain applications with a filter if needed.
It would be nice to have an RPM distribution as well. :smiley:
Agreed. I don’t care for flatpacks or some of the other install options. None of those are as clean and as manageable as simple .rpm installs. If you are providing .deb installable files, then .rpm’s should not be a stretch.
Apparently there is a .tar.gz, though you’ll need to create your own .desktop file. Can do the normal extract to /opt and symlink the executable to /usr/bin.
An RPM would be much nicer though.
.tar.gz is here:
I’m using the Git community plugin and it can’t see my SSH key to authenticate into GitHub. After all of my troubleshooting, it appears to be because Obsidian is in a container and it can’t see my local SSH keys. An RPM package wouldn’t have this problem.
a rpm would be very nice. bump!
Fedora and openSUSE are becoming increasingly popular among everyday users and developers; providing RPM packages (and official repository) would be great!
I would like to see this as well.
Yes please
i think you could use this tool to automatically build rpms
It is a shame that Obsidian doesn’t provide .rpm package for Fedora, OpenSUSE. I have been using Obsidian for a long time, on Fedora, I have to use Flatpak version of it to be able to update the program. Please provide RPM package!
Please Provide the RPM package for Linux
Many people are fans of the Fedora and OpenSUSE distributions. The RPM package will enable native integration of the Obsidian application for these distros and make maintenance of this application easier and more robust.
Increasing popularity in linux and fedora especially, a .rpm package will really help the new users ease into obsidian.
Due to the nature of flatpaks they are sand-boxed and that comes with both increased security and inconvenience, such as inconsistent workflow with ssh, overall slowness compared to native package & etc.
Appimage, i need a app to use the other app, not very intuitive and one extra app for just one app.
And i know I m asking a lot of work from the dev team but you can drop the snap package, snap is overall not good, not well received around linux folks and flatpak itself is better option than snap.
Tying it all together, a .rpm package would be nice plus for the community.
I’m really shocked that after all this time there is still no rpm. Is it really that difficult to enter few commands to generate a rpm and make it available for download?
Dear Obsidian team, if you don’t know how, here’s an example:
alien -r -g -v ./obsidian.deb
cd obsidian/
sed -i ‘s/Summary:/Summary: obsidian-app/’ obsidian.spec
rpmbuild --target=x86_64 --buildroot $PWD  -bb obsidian.spec
Started using Fedora recently, after using Obsidian for over a year, and was disappointed there’s no native rpm. +1.
I really need native rpm package! but why not provide rpm after long time?:skull::skull::skull::skull:
+1 for an rpm, for an every day application, flatpak has a LOT of shortcomings and quirks, and plugins or scripts are sandboxed, that is not great. I find even more quirks on wayland for flatpak especially with keyboard shortcuts.
