Property not set automatically for a new note if bases filter criteria is wikilink and does not exist
  1. Create a new bases
  2. Set filter, e.g. ‘type’ IS ‘[[quick capture]]’
  3. Tap a new note button (plus button)
Yes
A new note with a property ‘type’ set to ‘[[quick capture]]’
An empty note is created
Obsidian version: 1.13.6 (361)
API version: 1.13.6
Operating system: Android 16 (samsung SM-S938N)
Webview version: 150.0.7871.181
Live preview: off
Plugins installed: 36
Plugins enabled: 20
	1: Tasks v7.22.0
	2: Calendar v1.5.10
	3: Advanced Tables v0.22.1
	4: BRAT v1.4.1
	5: Share Note v1.5.5
	6: Trash Explorer v1.2.4
	7: Code Styler v1.1.7
	8: Share to NotionNext v2.8.4
	9: File Cleaner Redux v1.14.0
	10: Excalidraw v2.20.2
	11: Improved Random Note v1.0.4
	12: Dataview v0.5.68
	13: Meta Bind v1.4.10
	14: QuickAdd v2.12.2
	15: Global Search and Replace v0.5.0
	16: File Explorer++ v1.3.1
	17: Advanced Exclude v3.1.2
	18: Advanced Note Mover v1.2.0
	19: File Explorer Note Count v1.2.4
	20: Daily Notes Editor v1.1.0
Recording:
https:://youtube[.]com/shorts/I9U6sXTefMI?si=c-lrYliejixGVipb
FYI:
The new button won’t add the link if a note called “quick capture” doesn’t already exist. Once you create a “quick capture” note, pressing the new button on the base should add the value the way you expect.
thanks, update the title
will be fixed 1.14.0. ETA unknown.
