Properties panel in right sidebar
I like Properties, but I don’t need to see them at the top of my doc. I switched to “hidden” but now every time I want to edit them I have to switch to “source mode” and it only shows YAML and not the Properties implementation.
It would be nice to have a tab in the right side bar that displays and allows editing of Properties. This would allow quick entry while keeping the document clean.
None.
I posted the same in Plugin ideas, not sure how to decide which one is right. I don’t care if the feature is implemented in main or as a plugin.
This is possible already. Moved to help.
Isn’t this already available through enabling plugin in Settings > Core plugins > Properties view ? After enabling execute the command: “Properties view: Show file properties” from the Command palette.
Related topic
