Properties: Multiple Links Issue
  1. On a new note enter ‘—’ to trigger the properties plugin
  2. Add a text property named ‘Links’
  3. Enter double square lefthand bracket… The modal pops up with a list of links
  4. Select a note to link to and enter double square righthand bracket… the (underlined purple) link is formed
  5. Then on entering a second link by clicking on the edit symbol
  6. Enter any separator ‘,’ or ‘space’ or ‘|’
  7. Enter double square lefthand bracket… No modal pops up
  8. On entering the second link without lookup, the first link is destroyed and amalgamated with the second link, creating rubbish.
I expected that on entering double square lefthand brackets for the second link, a modal would pop up endabling me to select a note to link too.
  1. On entering double square lefthand brackets for the second link… No modal pops
  2. Continuing to enter the name of the second link, the first link is destroyed and amalgamated with the second link.
Obsidian version: v1.4.5
Installer version: v1.4.5
Operating system: Darwin Kernel Version 22.6.0: Wed Jul 5 22:21:53 PDT 2023; root:xnu-8796.141.3~6/RELEASE_ARM64_T6020 22.6.0
Catalyst license: none
Legacy editor: off
You need to use a list property if you want a list, not text property.
