Properties in document: visible, weird indentation
how do I make the property tab reallign with the document body? I think this appeared with the latest update.
Does this happen in the Sandbox Vault (you can open through the command palette or in Help) using the default theme, no css snippet and no plugin (or with Restricted mode toggled On) ? :thinking:
In addition to everything Pch said, if that’s the Minimal theme (it looks like it is), you should update it.
