Hey everyone,
I created a new vault inside my OneDrive Folder (to sync my notes between my computers). When I try to create a new note page, obsidian does nothing.
After that I added a test.md file in the vault folder via the windows explorer and notepad.exe. The file gets recognized in Obsidian, but I wasn’t able to edit that page. At least Obisidan showed me an error message (see attached image, I translate: “File saving error”.):
When I disable the synchronisation in OneDrive, I can create new note files/folders and can edit/save them.
So the Problem has something to do with OneDrive, but other apps I have installed work perfectly fine with files on OneDrive (even when the synchronisation is turned on).
I’ve heard from other people, that their obsidian vault on OneDrive works fine, so it might be a problem on my end…
This bug is very annoying, because I don’t want to disable the synchronisation everytime I write down some notes…
Anyways, looking forward to your answers!
Thanks in advance!
- Create a new vault inside OneDrive (Win10)
- Try to add a new note page or folder
A new note page that I can write stuff in that gets saved.
Nothing happens, not even an error showing.
- Operating system: Windows 10, latest stable
- Obsidian version: v0.11.9
