I’m not sure if this is what you’re after, but you can select a note in the sidebar, then hold “shift” and click the another note in the sidebar. You will then have selected all the notes inbetween. Control however doesn’t seem to work and you can’t select multiple files individually afaik if that’s what you were after.
