I try to decrease the width of an indent you can see at the picture. It is so wide only in edit mode while perfectly normal in reading mode.
I tried many settings with no result. No idea how to change.
If I understand you right, Settings > Editor Readable line length.
Oh, you know what, maybe you should check your theme and any CSS snippets, too (both in Settings Appearance). I didn’t understand your picture before because the main text was so far to the side that I thought it was a sidebar and the main area was empty.
That’s definitely not normal. If the problem isn’t your theme or a snippet, maybe it’s a plugin.
When you change themes or turn a snippet on or off it should take effect immediately but (especially with themes) it may be best to restart Obsidian to be sure.
OK, click the check mark at the bottom of the post that solved the problem to mark it as solved (or if you used a different solution post that and mark it), then start a new thread for the second problem.
OK. Sorry. I will. Thank you!
