Problem with physical keyboard on Android
iOS
Android
Obsidian Mobile version: v1.8.4
When using a physical Bluetooth keyboard (RK-H81), the built-in keyboard hides as needed, but the text is no longer printed. That is, the physical keyboard writes only one symbol, after which you need to click on the text again, after which everything repeats
Are you using Samsung Board, then perhaps you have this problem
I have the same issue on a Lenovo P12 tablet with original Lenovo keyboard. Deactivating community extensions and themes is without effect.
Tried a completely new vault: same effect. After each keystroke on the hardware keyboard the focus is lost and the toolbar gone.
Worked until about 3 weeks ago.
The issue may come from the touch keyboard. The effect occures with Microsoft SwiftKey Keyboard, but not with default Google Keyboard (GBoard).
I have the same problem (Galaxy z Fold6 smartphone, PowerAdd keyboard). The external keyboard works perfectly in other software, but in Obsidian it keeps jumping after a key input. It continues to work, you can press TAB 6 times and then you are back in the text field - and the game starts all over again. Without all internal and external plugins, the error remains.
