Problem with Mandatory Canvas Auto-Zoom on Mobile (Android)
​To the Obsidian Team,
I am writing to report a severe workflow disruption in the mobile version of Canvas (Android).
The existing mandatory auto-zoom behavior actively prevents efficient text editing, especially when I work with longer notes.
​The canvas view automatically scales out (zooms away) whenever an edit action is initiated on a card. This behavior is extremely intrusive and is triggered multiple times.
The zoom-out occurs the moment the card is tapped and the keyboard appears.
This auto-zoom re-triggers aggressively every time I attempt to move the cursor position within a long text card.
The view constantly scales out to fit the entire card height, making the text tiny and forcing a manual zoom readjustment after every small cursor shift.
Simple text correction becomes impossible.
​Please introduce a toggle option in the Canvas settings to disable this automatic zoom/scaling behavior when a card enters edit mode on mobile. This level of user control is essential for mobile usability.
​Thank you for your attention to this critical concern.
Welcome to the forum. There is a bug report template that is to be filled out for bugs. I’ve moved your topic to Help for now.
Can you please post your “Show Debug Info” results from Obsidian?
In the meantime, there are standard troubleshooting steps to try, if you haven’t already: About the Bug reports category - #11 by system
Thank you for the guidance and for moving the topic to Help for now. I apologize for not including the required template, as I am a new user.
I confirm this issue is a critical and reproducible bug in Canvas, not a troubleshooting request.
Here is the requested information to move the topic back to Bug Reports:
Operating system: android 13 (CUBOT KINGKONG 8)
Webview version: 142.0.7444.102
Obsidian version: 1.10.3 (251)
API version: v1.10.3
Plugins installed: 0
Plugins enabled: 0
I also confirm that the bug (the aggressive auto-zoom re-triggering when the keyboard appears after being manually closed) is still actively present in the latest mobile version: 1.10.3 (251).
Video Proof (Google Drive):
drive. google. com/file/d/1NNiH3ret8gmkp6kDSDm2oCgIxaoJXJrd/view?usp=drivesdk
