Greetings. When I try to sync my vault in Pop OS, I get an error about the password, but I have already tried it on the web, on Android and on Windows, and the password works.
I have community plugins is activated.
I have not made changes to the obsidian theme.
Obsidian is installed on Pop OS via flatpak.
the password only has letters.
This comment makes me curious. What do you mean on the web?
Each remote vault you make has a distinct password. This per-vault password is separate from your Obsidian.md account you use to login to the app.
You said it worked in other places, so maybe you already know that! Iām just checking.
Users have reported to the support box that trying a different installer seems to work for them.
What installer are you using?
system
Closed
May 22, 2025, 12:15am
4
