I have a mix of Macs and Windows computers that I use Obsidian for. I should also mention that I have only been using Obsidian for about a month.
I have a template for my daily notes that creates some links and gets the daily quote.
Template looks like this:
I am using Templater to retrieve the various date values (this is the only way I have been able to figure out how to do what I want to do.)
When I try to run the Templater template on a Windows PC, it works fine. When I try to run it on a Mac, I get the following error: “Template parsing error, aborting. Check console for more information”
Would appreciate any assistance anyone can provide.
To check for errors, first open the developer tools by pressing Ctrl-Shift-I on Windows/Linux or Cmd-Opt-I on macOS, and then go to the “Console” tab. If you want to save the error to a log file, you can right click on the error and choose “Save as…”.
The API used to provide the quotes is currently offline for me, I would guess that that is the problem.
So if I am reading the GET command properly, it is failing on api.quotable.io/random. What has me puzzled is the fact that it works on Windows, but not on Mac, on the same network.
