Problem converting a note to a Cornell Note using the template. It just embeds the code in the note instead
I have the correct CSS snippets and use the suggested Cornell template to convert a note into a Cornell note. However, using the Template command “Cornell Note - Make a Cornell note” simply inserts the code into the note instead of converting the note into a Cornell note with the Property and CSS etc.
I have tried to add a cue to a Cornell note and it embeds the cue code too
You’ll need to provide those or a link to them for anyone to be able to help troubleshoot.
Thanks for the reply. Here are the CSS snippet and templates. When I use them their codes are embedded in the note instead of just working.
cornell.css (15.4 KB)
[Cornell Note - Make a Cornell Note.md|attachment]
(upload://xgrAaERh7p2Aomanw6irSJVBpQn.md) (1.3 KB)
Cornell Note – Add cue to document.md (69 Bytes)
Just found my problem. I was inserting template without using Templater. Sorry for my ignorance!! Thanks for engaging with me.
You’re welcome! I’m glad you figured it out,
