@Cecilia_May , thanks for the explanation and pointing me to official documentation. I thought the Scheduled, Rescheduled are also Callouts, which they are not.
This is an Obisidian-related issue rather than a theme one. On the default Obsidian it works just the same:
If I add a bullet for the first item on the second list it renders the task:
I cannot add or fix functionality that is built in Obsidian. I can only change the look! I also think this has been the way markdown works? If not you can post a feature request or if this has always worked for you, you can post a bug request - here on the forum.
Hi, I love your work, is my favorite theme! I was wondering if you think it could be posible to customize the background of the graph view without change the main background
Ooooh! Interesting suggestion! I will add it to the list for the next customization update. The Graph View has some limitations so I will have to test if it is viable. I’ll let you know once I experiment :3
Hey folks! v.1.4.4 is out! Contains a ton of new customizations options, styling, improvements and fixes.
New
Added style options for Side Dock Ribbon (utmost left and utmost right narrow sidebar in Obsidian). Styles includes: Mini Floating Side Dock, Show on Hover Side Dock (inspired by tingmelvin 's Side Dock), and Hide Side Dock
Added style toggle for Hide Note Header Bar, Show on Hover. See gif for implementation. (chrisgrieser - I’m getting real inspired by you recently )
Added style options for Status Bar including Only show Sync Icon, and Hide Status Bar
Added tons of Customizations (1) including Header Background, Header Border, Header Border Radius, and Text Alignment — get them through Style Settings plugin
Added tons of Customizations (2) including change text colors for bold, italic, resolved and unresolved links; change blockquotes colors (text, border, background), change sizes of popovers and more!
Fixes
Improved contrast for dividers when editing the syntax
Fixed inline code not styling properly inside Callouts
Fixed #101 - will update again once Licat changes to the right variables (as said in the linked Discord convo by miharekar)
Fixed #91 - Typewriter Scroll plugin now works with Primary!
Increase modal size #85
Changes
I moved some style settings around, added dropdowns where needed, and added descriptions
Changed horizontal rule syntax font to code font
Changed checkbox box color #95
Changed footnote citations color to green
Changed external link icon
Improved Primary Documentation
Made multicolor highlight native rather than a must-toggle feature. You can disable this through Style Settings!
I also reworked the links so that they will have less specificity over all. I hope that its not colliding with plugins like Supercharged Links anymore
Noticed that with the latest update it’s not showing the checkmark for the checkmark items. Not sure if it’s issue with the primary update or the latest Obsidian version 0.14.4 . But checkmarks are working fine with other themes, which suggests that issue is likely with the theme.
hello there! I was using a variable that Obsidian provided but they changed the name in v.0.14.4 - so it broke. I’ve since updated it in v.1.4.5 of Primary! Please update your theme
Hi Cecilia,
I’ve been trying to use the Primary theme, but I’ve had a recurring issue that after 15 minutes or so of installing the theme, my vault just reverts back to the default theme. Each time I’ve tried to reinstall it, the same thing happens. It works fine for a bit, but then goes away.
When I go to the settings it doesn’t show the Primary theme in the list of installed ones (while others that I’ve installed do).
But when I scroll through the list of community themes, the Primary theme still shows up as “selected” (instead of “use”).
And when I check the themes folder, the Primary.css file exists there. I’ve tried deleting it from there and reinstalling the theme, but that didn’t resolve the issue either.
I’ve tried closing and reopening Obsidian but it was still having the same issue.
I haven’t had this happen with any of the other themes, so I’m not sure what’s causing it. Any help on how I could resolve this would be super appreciated, since I really liked the theme and would love to be able to use it!
Update: Actually I think I’ve realized what the issue is. It’s a little bit random actually haha. Not at all related to Obsidian or the theme. It looks like my Mac was uploading the file to the cloud to save local storage, which is why Obsidian wasn’t able to access it even though it kind of looks like the file is still there.
Absolutely gorgeous theme! Thank you for contributing something so awesome to the community.
I apologize if this is answered elsewhere, I did my best to search around but wasn’t finding anything mentioning this specifically… is it possible to use your alternative checkbox statuses in dataview queries?
I’m trying to sort out tasks based on the additional checkbox statuses that you’ve added through the theme.
