- Open a sandbox vault
- Go to page “Create your first note”
- Open the backlinks pane
- Preview the first backlink “create a vault” by using CTRL + hover.
(Hover over the block that reads “Now that you’ve set up your vault, you’re ready to [[Create your first note]]”.)
Yes
The preview auto-scroll to the correct paragraph where the page is mentioned.
The preview started from top instead of scrolling to the correct paragraph.
I’ll have to manually search the correct paragraph.
Obsidian version: v1.6.3
Installer version: v1.4.16
Operating system: Windows 10 Home 10.0.22631
Catalyst license: none
This bug has been around for quite some time. When the page is long, manually searching the correct paragraph could be a tedious task, so I hope this could be solved swiftly!
