Preview Note body in Base view
Hi all,
I’m looking to see if there’s a way to show the first ~100 characters of a note in a base table/card view? A lot of my notes are quick thoughts that don’t warrant titles. This makes it tough to scan through tables since the note body is the only thing giving context.
I’ve checked through the forums but haven’t found much luck on an answer. Seems like Obsidian doesn’t natively support showing the body text of a note in a base view?
I’ve also looked into Dataview and have found luck being able to display body text in its tables. However I can’t find a way to truncate the text effectively (things like bulleted lists take up a lot of screen space)
Any help appreciated!
Bases don’t/can’t read the contents of notes, only the Properties and cached metadata about the note, so that’s out.
Some folks, including me, have a longer description in the YAML/frontmatter/Properties that you can view in Bases. This one was created by the WebClipper; others are manually entered:
There may be a community plugin that adds the first 100 or so characters of a note to a Property automatically. If not, I’d like to see one.
I used the Obsidian Feed Bases plugin to do this. I wish it was a bit more customizable, but it’s been working great so far.
