adjusting plugin, reading posts
i have the latest release, and the preview pugin on, but can’t seem to get a preview in the graph. holding down cmd.
btw, is there also a way to preview w/o requiring cmd?
You can change the behaviour in Settings → Plugin settings → Page preview
In the graph view, you have to hold down cmd before putting your cursor on the node. The other way round it does not work.
Tell me if that helps!
got it! I didn’t know you had to hold it before as it’s the other way around… and I get the pref pane now… require cmd is set individually per item, not a global thing. thanks!
