Pressing the `Undo` shortcut while in settings undoes note edits
In the Sandbox…
  1. Type “lorem ipsum” in a note.
  2. Open Settings > Core plugins.
  3. Type “a” in the text input box then press Ctrl + Z. (The “a” gets undone.)
  4. Press Ctrl + Z as many more times as you please.
undo beyond context
Y
Note edits are unaffected.
The note content “lorem ipsum” gets deleted.
Obsidian version: v1.11.6
Installer version: v1.11.4
Operating system: Windows 11 Pro for Workstations 10.0.26200
Catalyst license: insider
Insider build toggle: on
Plugins installed: 0
Plugins enabled: 0
  • Step 3 is unnecessary.
    • Ctrl + Z from any settings tab can undo note edits.
    • The search box just shows a use case for using undo in settings.
    • It also demos that even when focus is explicitly given to a settings text box, undo can still undo note edits.
  • Redo
    • Pressing Ctrl + Y from the settings modal doesn’t restore the note’s content.
    • After closing settings and returning focus to the note, pressing Ctrl + Y does resort the content.
Can repro on macOS:
CleanShot 2026-01-28 at 20.16.07
	Installer version: v1.10.6
	Operating system: Darwin Kernel Version 24.6.0: Wed Nov  5 21:33:58 PST 2025; root:xnu-11417.140.69.705.2~1/RELEASE_ARM64_T6000 24.6.0
	Catalyst license: supporter
	Plugins enabled: 0
thanks
