Press and Hold Delete Key in Android/Gboard
Using Android, if you place your cursor at the end of a sentence and then press and hold the delete key.
Words are deleted one by one.
In the past when you press and held the delete key, the text was deleted word by word. If you knew that three words needed be deleted, you could press and hold and just count the number of haptic pulses that you would feel and then release the delete key. Now, I need to press the delete key and wait a long time before the words are eliminated.
If you place your cursor at the end of a sentence and then press and hold the delete key, characters are deleted one at a time.
  • Operating system: Android 12
  • Debug info:
    Operating system: android 12 (Google Pixel 6 Pro)
    Legacy editor: off
    Snippets enabled: 1
    Safe mode: off
    Plugins installed: 2
    Plugins enabled: 0
    Version: 1.1.0 (38) API v0.13.24
This bug was introduced with the most recent version 1.1.0 (38). API v0.13.24.
This report was repro’d with third-party plugins off. I don’t have any custom CSS.
Related to this:
Which keyboard are you using?
I’m using Microsoft SwiftKey. But Google Keyboard shows the same behavior.
