Possible bug with Calendarium
I have been trying to add an event that span over a month to my calendarium, but it seems that calendarium fails at that.
I tried inserting into the properties fc-date and fc-end, and the date is before the end of the month, while the end is after, but in the Calendarium sidebar the event appears only until the end of the month. It works fine if beginning and end are both in the same months.
It might be worth mentioning I am using my own fantasy calendar while doing this.
Hopefully someone can chime in here, but if it’s a community plugin issue, I go straight to their GitHub page and look for similar issues, double-check their README and setup steps, etc.
Their GitHub page is linked in Settings > Community plugins > Plugin-name.
I wasn’t clear on how to proceed for these kind of issues, I am still new to the Obsidian community.
Thank you for the advice!
Here is perfectly fine to ask :blush:, but poking around their GitHub may lead to some answers. Good luck!
I found it between other open issues in the github. I will go from there, as it seems to be a known bug. Thanks again for the suggestion!
Link to the issue on github.
