when i use the internal links and backlinks ,it shows,“position 94 is out of range for changeset of length 0” and can not open the note(instead,it shows ‘no file is open’).
Please resubmit this bug report and make sure that: 1) you follow the bug report template, 2) you use the default theme (no css) and 3) there are no third-party plugins enabled (You can use the sandbox vault for 2 and 3).
