Pomodoro timer integration with obsidian and process that timing data, is that possible?
This is my directory structure.
Here’s the flow.
I open 2024-03-11 note.
It consists of a timer with an option to select what I am studying at that moment Example: I’m studying Linux, or Kubernetes or learning to blog in Hugo or learning Docker. There will be few specific subjects that I will be learning and I want the timer to grab that data from Goals/* directory so that automation is possible.
I put the timer on. Say, the timer worked for 45 minutes, now I want the time to be counted.
The time 45 minute now goes for processing.
There will be a dashboard for every week where I’ll compare my weekly goals are achieved or not.
Say I planned to learn Linux for 5 hours per week. Now, say I studied Linux for only 2 hours that entire week. Thus, my progress bar will be 2/5*100%=40%
This is the automation I’m trying to achieve in obsidian. Is it feasible? Can you guide me?
I’m not sure if any of the “Pomodoro” related plugins might be of any assistance to you? But there are a few of those, so maybe one of them could do the trick?
After a quick glance through, maybe the Pomodoro Timer could be one for you, as it seems to have some Daily notes integration stuff and thusly tracking of time spent on a given category.
